need a part for 51 Hornet
Unknown
Hope i'm posting this in the right place..... I'm looking for the bracket that holds the steering column to the bottom of the dash..... Mine must have had a crack in it and when we took it apart it broke.............BUMMMMER......... Big Dan
  • HI DAN, was cruisin Ebay a few minutes ago and thought I saw one on there. Think I just had Hudson entered as a search item in ebay motors
  • YEAH I DID for a 54--rechromed --OUCH--70-80 bucks !!!---item 260165467046
  • 7XPacemaker
    7XPacemaker Senior Contributor
    Need to specify if it has turn signals or not, if it is the piece that I am thinking of.....
    That price is not bad considering the cost for rechroming & the part is probably the same as the other step-downs.---Cliff Minard.
  • Contact Hudzilla, He is on here off and on. Almost sure he has one and He is reasonable on his prices.
    Bob
  • Walt-LA
    Walt-LA Senior Contributor
    Dan,
    Which part do you need? The bottom, chromed piece which goes under the column, or the plain metal bracket which attaches to the dash frame and is over the column? In any event, Hudzilla is a good source. PM me if you can't find his address here, I'll give you a phone No. Walt-LA.
  • Thanks Guys.........Hudzilla's got what I need.............Big Dan
  • Browniepetersen
    Glen Johnson also has a few of these available.
