window rubbers
essexcoupe3131
As you all know I am starting to finish my coupe (31)and I have realized that
these have a couple of different shaped window rubbers
I am trying to find where (if I can) buy these.
I am looking for the rubber that goes on the exterior side of the door and is wedged between another piece of steel and makes the weather strip
and then theres 1 on the bottom of the interior window frame and acts as a gasket and weather seal at the same time, i think I have sorted out the glass felt
Any help would be greatly received or any suggestions of a alternative
thanks Mike
thanks Mike
Have you tried K-Gap http://www.k-gapstore.com/servlet/StoreFront ? They specialize in Hudson rubber and plastic parts.
Restoration Specialties and Supply http://www.restorationspecialties.com/ carries parts for all makes of antique cars, but they do have hard-to-find items that happen to fit Hudsons and Essexes.0 -
Mike
I got some from Horopito Motors, Ohakune. They have all sorts of profiles and the one I got for the exterior needed trimming on the hidden side and works well. If you want I can send you a piece (if I can find a scrap left over) so you can see if it will work. Send me an e-mail if you want.
Alistair0 -
Check with Dany at K-Gap. He showed me the sweep he made for a '30 when he was in Auburn. I think it was the one that fits on the outside with the metal strip.0
I will try the different sources amd see how I go start in NZ and start working towards the US
the one on the interior frame looks interesting
thanks to you all
Mike0 -
Hello Mike, I (Vic's Auto Window Channeling) have the window channeling for the 31 coupe and the outer beltlines for the windows, back widow also. Kgap has the inner sweep for the window. See add in WTN0
Hi Victor, what would the cost of all the rubbers and welts be for my 31
sent to me in Auckland, New Zealand
Would it be possible to consolidate with K-Gap so I had 1 shipping charge
Best regards Mike
you can email Me
Do you take Amex or Visa ?
Mike@essex-comshape.co.nz0 -
I will check with Kgap! VicTor Z0
- 175 The Flathead Forum
- 602 Vehicles
