\'46 Hudson transmission
Unknown
Does anyone know where I could get a '46 Hudson transmission with overdrive on the west coast? I live in Hawaii so CA or WA would be great. I found one in Utah but shipping costs to the coast alone is $400.00 via Yellow freight. Across the ocean to Hawaii is only $99.00. Any help would be greatly appreciated.
Jeff
  • Check with Bill Albright in Fontana Ca. I don't have his # but it is in the roster.
  • To expand your search, any single lever thru early 52 is the same tranny. You'll have to bolt it to your 46 bellhousing.
  • Uncle Josh,
    My '46 came with a '49 262 and transmission. Could I bolt a '46 bell housing to the the '49 transmission? I think I had asked Walt Mordenti and he said I could not bolt the two together. He said the transmission would not seal and would leak into the clutch. That would be great if I could bolt the two together. Thanks,
    Jeff
  • Far be it from me to disagree with Walt for I follow his advice. He must have had a bad seal for I have a 49 OD tranny bolted to my 46 pickup 6.
    The cutaway drawings in the 41-47, and the 48-54 manuals are
    the same but to be sure, I just got back from the shed where I have both a 47 and 49 Bellhousing and tranny. I took them apart and the seals and shafts are identical. I suspect the leftover 47 trannys all made their way into 48s as I can't tell the difference.
  • Thanks Uncle Josh,
    I checked with walt again. he said he checked the manuals for both and they are the same. So I will be getting a bell housing from Glenn johnson. Thanks for the help.
    Jeff
  • Bill Albright e-mail is albrighthudsons@msn.com
  • I have transmissions and bell housings, do you need a three speed with overdrive, or without. Bill albrights Vintage Coach, Fontana, cal, 70 miles from the dock.
  • Thanks Bill,
    But I just sent out my payment today for a bell housing from Glen Johnson. I may need other parts later on though and I will contact you then. You are much closer and it would be alot cheaper for some of the larger parts I may need. Again Thank you everyone!
    Jeff
  • You can ship UPS 2nd day air to Hawaii. Ups now takes up to 150 lbs, which would cover a transmission. They would be a lot cheaper !
  • Does anyone know where I could get a '46 Hudson transmission with overdrive on the west coast? I live in Hawaii so CA or WA would be great. I found one in Utah but shipping costs to the coast alone is $400.00 via Yellow freight. Across the ocean to Hawaii is only $99.00. Any help would be greatly appreciated.
    Jeff
    I live in Southern CA and have a 1949 6 cylinder with overdirve trans that I am willing to depart with.
    Greg
