Window install question
Yep thats the drill Jerry. And don't forget to put the vent window channel in before you install the window and crank . Here is a trick you can use for the installation job. Use old atheletic socks that the toe section has been cut off. Slide them onto your arm until the toe section is just below your wrist. Now you can install the crank and window mechanism without the sheetmetal shredding your wrists.
Have fun! 0
