Repro 1954 parking light housing clips
I work at a plant that uses all stainless steel to make water conditioners and water distillers also truck assessories. I am in the process of making clips for the 54 hudson front parklight housings .allmade from ss.including the stud flatwasher lock washer and nut. I will sell the clip or send me the housing to spotweld clip on or spotweld on new ss studs. This would save a lot of these housings that might be still salvageable.
Xbyvank@telus.net (delete X before sending)
[NOTE: I am posting this message at the request of Classiccars, which received the above message from a fellow who didn't know how to post this message. Please do not respond to me personally, as I know nothing further than what is posted here.]
Jon, you know a lot more than you think!0
Thanks jon for the post. At the place where I work ,we have punch
presses and bending machines. welder. a person that welds studs
and I do acid washing of welded parts also polishing of stainless steel.
I hope this idea works because I think their is lots of housings that
need these ss clips. After NewYear I will getstarted getting the clips
made. Maybe the 48-53 Hudson are the same. Anybody interested.
duncan0 -
Im in if you do the spot weld and polish. let me know when,where to send my housings, and how much. Excellent idea and service to fix a common problem for us 54 owners !:)
Chris0 -
- 175 The Flathead Forum
- 602 Vehicles
