21st Century Hudson Website
hi guys will be updating the website in the next 2 weeks with more items and updated prices. Machining has gone up on some items. Things we have added are unisyncs, center steering kits for 41-47, clutch alignment tool, rear leaf springs for 41- 54, pertonix with or without rebuilt distrib, complete gasket sets for 37-56 and/or specific gaskets and clutch fluid.
russ
russ
Russ, do you stock valve springs?0
Russ, can you do a 12V Pertronix conversion on the stock 212 distributor???
Out of curiosity, what is a unisync?0 -
66patrick66 wrote:
Patrick, A Unisync is a device used to synchronize a twin H setup so that they will both cars will be in unison when the accelerator pedal is pushed. Two carbs not working together is bad for mileage and performance. The device itself works by placing it over the air intake hole of the carb and setting the idle adjustment to match both carbs. The vacuum created pushes a small ball up a visible column and you match the height of the ball for both carbs. They generally sell for about $35.Russ, can you do a 12V Pertronix conversion on the stock 212 distributor???
Another new thing learned! Thanks!0
Patrick
The following is a sheet on the unisync... that is posted to my website
http://members.aol.com/sanjuana/Incoming/UniSync.pdf
The following is a sheet on using the Unisync to adjust a Hudson Twin H carb system
http://members.aol.com/stepdown53/TWINHADJUSTMENT10001.htm
Happy New Year0 -
uni sync's rock... if you have a twin h, you should have one. Cheap and easy tool to take away the issues with trying to get the carbs in sync. Makes minutes out of a long drawn out job.
click on the link in my signature list to access 21st century's website, our if you like, give Ole Ken Cates' site a try. Either way, you're doing yourself good. Heck, try them all, good stuff.0
