21st Century Hudson Website
hi guys will be updating the website in the next 2 weeks with more items and updated prices. Machining has gone up on some items. Things we have added are unisyncs, center steering kits for 41-47, clutch alignment tool, rear leaf springs for 41- 54, pertonix with or without rebuilt distrib, complete gasket sets for 37-56 and/or specific gaskets and clutch fluid.
russ
russ
Russ, do you stock valve springs?0
Russ, can you do a 12V Pertronix conversion on the stock 212 distributor???
Out of curiosity, what is a unisync?0 -
66patrick66 wrote:Russ, can you do a 12V Pertronix conversion on the stock 212 distributor???
Another new thing learned! Thanks!0
Patrick
The following is a sheet on the unisync... that is posted to my website
http://members.aol.com/sanjuana/Incoming/UniSync.pdf
The following is a sheet on using the Unisync to adjust a Hudson Twin H carb system
http://members.aol.com/stepdown53/TWINHADJUSTMENT10001.htm
Happy New Year0 -
uni sync's rock... if you have a twin h, you should have one. Cheap and easy tool to take away the issues with trying to get the carbs in sync. Makes minutes out of a long drawn out job.
click on the link in my signature list to access 21st century's website, our if you like, give Ole Ken Cates' site a try. Either way, you're doing yourself good. Heck, try them all, good stuff.0
- 175 The Flathead Forum
- 602 Vehicles
