Why Would Exhaust Manifold Gasket Blow
My '29 Essex kept stalling every time I took my foot off the gas and I
had to resort to rolling starts to make it home because the battery was
finally exhausted from all the restarts. Once in the garage, I found
black smoke puffing from under the exhaust manifold next to both of the
long exhaust manifold studs. (Part #BM 63553) I'm probably getting the
wording wrong but I believe it is directly under the carb riser to
exhaust manifold and bounded by the long studs.
My question is before I simply take off the carb and exhaust manifold
to replace the gasket, what would cause exhaust to blow-by this area at
idle (and running) when it was working like a top all morning?
I'm still new to motor teardown so perhaps I'm missing somthing basic
like ????
THanks
David Weinstein
'29 Essex Roadster
'72 Corvette Cvt
like ????
THanks
David Weinstein
'29 Essex Roadster
'72 Corvette Cvt
As far as exhaust maifold gasket failure goes, age and improper installation are causes, but heat is the true enemy.0
It sounds like you have an obstructed exhaust system. Has the car been sitting, possible rat nest. Also, check to see if your the flapper in the manifold is stuck closed.
Harry0 -
Also check to see if the gasket surface of the manifold is true and flat.0
Dave, does it seem like it doesn't have any power? I'm wondering if it was running fine before this started happening or was this the first time you had it out. Does this car have a heat exchange butterfly flap to push hot exhaust gasses up to the intake until the car is warmed up. Maybe the it's stuck closed and is causing the manifold to get too hot. It could also cause the gas to boil in the carb and vapor lock.
Harry0 -
Check your that both your vacuum tank & your carb float are working as they should.0
Did it ever back-fire? If so, that would be an above-average amount of exhaust pressure, perhaps above the design pressure of the gasket, and potentially leading to the premature failure. When you replace it be sure to torque to specs and recheck the torque twice a year.0
