Guage trio installed in stepdown
Hey! Your installation does look good. Factory or not. Where did you pick it up, and what is the part #?
Dennis0 -
I purchased the trio model as an add on. 1.875" dia guages. Dissassembled the unit threw away mounting plate.
Used an old Hudson Heater control unit exactly the same as the one seen above the guages in the picture took all parts off it. Cut and polished stainless steel to fit guages into and mounted them into the old heater control unit.
Prior to installation I Faux finished the guage bezels to match my interior. You will also see in the picture a cruise control and signal switch with the same Faux finish.
Hopes this helps you out. Thanks Ray0 -
NICE SETUP: Ray, I'm interested in the cruise control setup, so I can get really relaxed on trips with my stepdown.
Any help in this area appreciated.
John
jgw2@bellsouth.net0
