Stepdown wiper blades
If I remember correctly, the Trico 33-101 was discussed here a while back. They're supposed to be correct if you use a 10 inch blade. Probably available from most parts stores.0
Dave53-7C wrote:
that would be correct for a stainless 10" the 54 uses an 11" I haven't confirmed it but if Trico Classic 33-101 is the correct 10", I would expect 33-111 to be the 11" of the same configuration.If I remember correctly, the Trico 33-101 was discussed here a while back. They're supposed to be correct if you use a 10 inch blade. Probably available from most parts stores.0 -
...or just contact Ficken's in New York, www.wiperman.com . They have new ones that fit cars waay back, even before my '37.0
Now the question is where. Seems like every place around here is supplied by warehouses that stock ANCO not Trico.0
Here are some part numbers for wiper blades.
10 Inch: Trico=33-101, NAPA=WIP 601033
11 Inch: Trico=33-111, NAPA=NA
12 Inch: Trico=33-122, NAPA=WIP 601233
13 Inch: Trico=NA, NAPA=WIP 601337
15 Inch: Trico=33-150, NAPA=WIP 601537
16 Inch: Trico=33-162, NAPA=WIP 601647
18 Inch: Trico=33-183, NAPA=WIP 601847
This wiper arm should work. Trico 51-062 or NAPA WIP 60750
{Adjustable Wiper Arm - 8 1/4" - 11 1/4", Wrist Action, 5mm Bayonet (1/2" Knurl, 10-32 Threaded Shaft, 1/4" Round Shaft, 3/16" Round Shaft, 15/64" Round Shaft)}0
