Torque specs
[Deleted User]
I'm looking for the torque specs. for the nuts on the u bolts that hold the front and rear axles to the leaf springs on my '39 (they would probably be the same from '37 to '39).
Kevin
  • There are no torque specs listed in my mechanical procedure manual i would say make them tight if they are half inch 90- 100 pounds of torque.
  • Geoff
    Geoff Senior Contributor
    Step-down and Jet service manuals specify "Rear Spring Clips" using 1/2"-20 U-bolts to torque down 70-80. These are the same as the '39 (including fronts).
    Geoff.
  • Thanks Chuck!
    It didn't require much torque to loosen those nuts after the jam nut was removed. I was a bit concerned because I'm replacing the old nuts with new grade 8 units.
    My manual doesn't have any torque specs for it either. My Motors manual has some torque specs but I loaned out and it hasn't returned yet.
    Kevin
  • My Motors manual does not list the torque specs. for these.
    Geoff.
    Once again Geoff answers the question that stumps rest of the Hudsonworld!
    Thank you Mr. Clark!
    Kevin
