1934 - 35 high compression head
[Deleted User]
Parts book shows high compression head "complete with cover". If it has a separate cover it must be very different than the standard head. Has anyone ever seen one of these or have any informatin about it? Iron or aluminum?
  • oldhudsons
    oldhudsons Senior Contributor
    yes, they are quite interesting!
    There was one for sale at the last Dearborn National - I bought it & gave it to my buddy for his Railton.
    It is a 2 piece iron head with a special 1 pc. copper gasket between the heads. They had an alum. cover over the head which was std. equip. for Railtons on some models.
    They are extremely rare.
  • Do you mean that it was divided front and rear - or divided some other way?
  • oldhudsons
    no, it's is divided front to rear, a lower 1/2 that sits on the block, then a copper gasket, then the top 1/2 and the cover uses the block studs to hold it on top of the entire assembly.
