flooded intake, '37 Terraplane
Hudsonrules
Arnie, Hudson considered this problem and came up with an answer 70 years ago. On the underside of your intake manifold there should be a one-way brass check valve with a brass or steel drain line coming out of it. The valve may have become dirty through the years or someone may have completely removed it and replaced it with a bolt. Remove the valve or the bolt and the gas should drain out!0
I would'nt worry none about it. If it is real excessive you could soak most of it up with a cloth. Cranking it over will draw the rest thru the engine and out the exhaust. No need to change oil. Just undo the fuel line before the fuel pump while clearing it. What little is left will enter and burn when you start the engine. BUD0
Its funny they only used that check valve on the under side of the intake for a couple years it might not have worked as great as they thought but i think they had some carb flooding problems that year and improved the carb in later years and got rid of it the next year?0
Hudsonrules wrote:
Took the carburator off my '37 Teeraplane as it was leaking badly and the engine would not start. I noticed that there is raw gas just sitting in the intake manifold due to the flooding. Question, how best to remove the gas, or just crank the engine over a few times and change the oil. Will the gas drain into the cylinders? May sound like a dumb question and i mam no mechanic, just learn as I go along. My parenbts would not let me take auto shop in highschool and so I have had to learn by reading books, asking questions and trial and error. Thanks again in advance. Arnie M.
- 175 The Flathead Forum
- 602 Vehicles
