Parting out a 52 4 dr Hornet
[Deleted User]
Am in the process of parting out a 52 4 door Hornet with 308 twin H engine and Hydro trans. Most body parts are junk but the front and rear glass is good. If anyone needs anything from this car please let me know as I will be taking the hulk to the scrap yard by the end of the week.
  • RL Chilton
    You are pulling out the engine and tranny, aren't you? For that matter are the carbs, linkage and air cleaners and/or manifold any account? Would be interested in those, possibly.
    If available, I'd like to purchase rear passenger courtesy cloth strap metal parts, I am having new cloth ones made, but old chrome shop lost supporting metal parts, also interior visor long rod, plus clips along with bolts that is bolted to inner roof and if you have replatable porkchop core forgot what side, will check with new chrome shop I am using tomorrow, last thing exterior roof antenna?
    Thanks,
    Ray
  • Uncle Josh
    Uncle Josh Senior Contributor
    Where are ya? I could use the rear axle differential assembly
    If it has the blue interior there a few pieces I could use.
  • I am located in North Carolina about 20 miles west of Charlotte. The car does have blue interior but it is in bad shape. Email me with specifics of what you need. Will remove the trim pieces from the rear assist strap tomorrow. The rear axle should be OK. Some of the parts of the twin carb setup are missing. I know the bellcrank and linkge for the front carb are AWOL as are the air cleaners. May be able to locate the air cleaners as they were in the trunk last November but were missing when I brought the car home on on Tuesday. Will have to have a talk with the chap I bought the car from. The exhaust manifold is broken where it connects to the exhaust pipe.
    Please PM me with any requests for parts.
  • Dear Birdman,
    To avoid any confusion of requested parts, the following picture is what I require, as you can see I have some already chrome plated, but not to cause you to seperate only pieces I need, I'll take both sides of supporting pieces for courtesy strap installed on door posts and visor rod, clips and bolts, also could use only door buttons with clips and springs, I already have plated handles, as I said last chrome shop lost some of my parts. As I can not post picture in PM please see FORUM. For the purpose of adding postage to whatever is fair price wanted I live in Las Vegas, NV. 89144
    Thanks,
    Ray
  • BHLHH52
    BHLHH52 Expert Adviser
    Trying to locate the plastic tube (blue) that fits under the antenna knob and up against the headliner. Any help appreciated and compensated for. Brent
