Headlight
If your car is 6 volt the sealed beam number is 6006. If memory serves me right, 12 volt sealed beam number is 6012, but I'm not 100% sure of that.0
yep...A 6006 IT IS...JUST INSTALLED THE NEW ONE0
'Glad that number was still available for you. I pulled it out of the cobwebs of my brain. I always have replaced my lamps in pairs. I figure that if one burns out the other is getting ready to do the same. I also use Dielectric Tune-Up Grease on the plugs. It makes getting the sealed beam unplugged much easier the next time around. I probably should have suggested these hints along with the part number.0
