hudson right side
Car looked pretty decent... Nice job posting Picture0
Nice looking car. Are you planning to keep a stock look or shave trim etc?0
It will have all of the trim minus rocker panels. I will have the frame line xed in blue and run functional laker pipes through frame,keeping fender skirts? the interior is done in a blue that replacates older style. Jvc satelite radio with updated speakers. ac this summer.0
keeping the fender skirts and not running the rocker trims can be done, but it will look very odd just ending it like that, may i suggest making a panel that sort of flows from the skirt to the lake pipes. you should be able to run the pipes straight out to the fenderwell and follow the outside of the rockers. may i suggest having kind of a "h" pipe running across to the left side laker and have it cut in half way down, making the front half effectively a dummy since getting a pipe out to the left fenderwell would be a tricky job considering what you have to clear.0
If you're eliminating the rockers, let me know. I need a set of sedan rocker panels for my '52.0
- 97 Essex Super 6
