Wiper Vacuum Line Routing
Shameless bump.
The professionals redoing the fuel, wiper and heating lines would like a picture of the wiper lines as they should be so they can do the job right.
Please post/send a picture.0 -
its just rubber hose from the wiper motor to the fuel pump routed through the clips spot welded on the right hand inner fender.0
I was going to ask the same ( well almost ) question. I'm using twin h manifold with a single action fuel pump . Is it recommended to put the wiper hose to the vacuum equalizer tube that goes on the intake manifold?0
Jimalberta wrote:I was going to ask the same ( well almost ) question. I'm using twin h manifold with a single action fuel pump . Is it recommended to put the wiper hose to the vacuum equalizer tube that goes on the intake manifold?
Yes, that will be fine.0 -
Thanks, Nick.
There is only one clip. In the preliminary discussions with the shop, we were looking at adding repro-looking clips to better hold the wipre tubing.
This puts us on the right track.0
- 114 Hudson 1916 - 1929
