235 dual intake
You should not need to do anything special for that set-up ; Just Tee the fuel line and adjust the carbs & linkage as equal as possible. Also Plug any vacume ports on the 2nd carb0
Thanks for the info Ol Racer, much appriciated.0
My pleasure.
Use large or low restriction air filters and To eliminate parasite drag (robbing power) install a clutch fan or better yet an electric fan. When have a lot of cubes maybe not much difference but on a 6 cyl its noticable0
- 111 Hudson 1916 - 1929
- 177 The Flathead Forum
