Spark plug wire
Jim Kilday
Jim Kilday Expert Adviser
We've almost finished the entire re-wiring in my 1946 Commodore Coupe. I want to use the correct spark plug wire and coil to distributor wire? What was the original wire used for these items?
I used a Y and Z and the work has been reasonable easy. The instructions are very good. Never having used Rhode Island or Naragannsett, I cannot comment on how they compare with Y and Z but we've had very few issues with the Y and Z harness.
Thanks,
Jim Kilday
  • I USE A CHRYSLER 318 OR 360 WIREILNG SET FOR SPARK PLUGS, EASILY OBTALINABLF ND HAVE THE STRAIGHT LELADS AT PLUG END AND DIST END AS ORIGINALLY USED USE THE 6 THAT DUPLICATE YOUR LLENGTHS AND THROW AWALY THE OTHER 2 OR USE THEM AS SPARES, I RETAIL LTHE SET FOR 30.00 OR CHECK YOUR LOCAL AUTO PARTS STORE, bill albrights vintage coach GOOD LUCK
