Hillholder
Does anyone know where I might locate replacement annealed copper sealing washers/gaskets for a Wagner "NoRol" in my '47 Hudson? The "banjo bolt" washers are available anywhere, it's the end cap and cam shaft cap items that I need. 3/4" X 1" X 1/32" and 1-1/4" X 1-1/2" X 1/32". the thickness is, I believe, actually 20 ga. @ .032
Should be able to get soft sheet copper at a roofing supply place. Would then have to make them.0
