Hudson Repro List now online
You may view my list of reproduced Hudson items at http://mysite.verizon.net/detailed1/Repro Table.htm. (For some reason this link worked only half the time, this morning, so try this one if you have a problem:
http://mysite.verizon.net/detailed1/Repro%20Table.htm)
(This is a new address since yesterday; if you bookmarked it prior to Sunday, please do so anew).
This list will constantly be updated. Please advise me of parts that are specifically being reproduced for Hudsons and I'll add them. If you discover that any items on my list are no longer available please advise me. Please advise of any errors and be forthcoming with your suggestions.
This is not an interchange list. At this time I'm not interested in parts which cross-reference with Hudsons, or modern-day items that can be made to fit our old cars. I'm only looking for parts which are reproduced to fit Hudsons.
The method of grouping parts is unique and may be modified, depending upon response of the users.
If you would be interested in becoming involved in this project (maintaining a repro list and updating it on-line) please let me know, at HETTerraplane@verizon.net (delete HET before sending).
Jon & Rick--- Thank you for all the work that I know went into the making of this list. I have book marked it of course. Cliff Minard.0
Jon - Nice Job on putting the list together.
Are you maintaining the list items directly inside of Word?
I can make you an Excell spreadsheet that you could maintain the lists in and then run a macro that would generate an xml file and transform it into an html file for viewing.
Anyway - if you're interested I'd build it for free just to promote Hudson more!
Dan
P.S. I tried to send you a private message through the forum - says your message box is full and needs to be cleaned out...0 -
Jon B]You may view my list of reproduced Hudson items at http://mysite.verizon.net/detailed1/Repro Table.htm. (For some reason this link worked only half the time, this morning, so try this one if you have a problem:
(This is a new address since yesterday wrote:HETTerraplane@verizon.net[/email] (delete HET before sending).
Maybe its just my webtv but the print is almost the same color as the back ground so I can not make it out. The heading in black and can see that great along with the contacts. Is anyone else having this problem or is it my crappy webtv ? I need a puter
Thanks Ron 0 -
What browser is that cr@p*y webtv using? It probably can't an html feature(s) used in the converted word document.
Maybe fuss with the brightness/contrast settings?0 -
Great job, Jon. I added link from my tips section http://home.earthlink.net/~dsollon/public.htm/tips.htm0
Awesome – I’ve wanted a few parts but gave up trying to find them. There they are in your list. Just awesome!!!! You guys are the best!!!!!!!!!!!!!!!0
I know the counterpart to this list, modern cross references is available, but it sure would be nice to have a second list, with current retailers, and perhaps prices, that list modern parts that can be adapted and where they can be bought and how much (approximate) organized as such. Ken Cate's (I hope I spelled his name right... Because I really own his site, to getting my hudson running) does a great job of listing a wealth of hudson info, but after seeing how the above mentioned list is organized, it might be nice to have a similar list with modern parts that work, organized as such. Anyone? I would be willing to contribute my limited knowledge of parts I found, and how much they cost... if it would help.0
- 111 Hudson 1916 - 1929
