Parts Needed, 51
I am not sure what you mean by "idler arm" as Hudsons don't use idler arms. On the picture below what part do you need.0
mars55 wrote:I am not sure what you mean by "idler arm" as Hudsons don't use idler arms. On the picture below what part do you need.
Mars55. thanks for replying.
I need the bushing and pin kit for the center steering arm, where it attaches to the frame member. These used to be readily available, however, I can't seem to locate a source now.0 -
Try Randy Maas at 21st Century Hudson for the Steering part. maasfh@ntslink.net
Try Dave Kostansek for the Seals @ 440 293 4079 or 440 994 91730 -
Which seals do you need? Norm0
herm wrote:Which seals do you need? Norm
Norm
The two axel seals on each rear wheel. They prevent axel lubricant from contaminating the brake shoes. In order to pass the California brake inspection I have to replace these.
After an accident my 51 Commodore was totaled by the insurance company. It is now repaired but to get it re-registered it must pass a pretty tough brake and light examination.0 -
Have Orig Seals. Blill Albrights Vintage Coach, Fontana, Ca0
- 114 Hudson 1916 - 1929
