Visor Brackets ?
If outside visor, I think Ken Amman was making repro's. I'm using a set and they're nice. 810-621-36650
Thank you Uncle Josh.. i'll try them today.. i know he sold the business but maybe the new owners might be able to help me..0
Uncle Josh wrote:If outside visor, I think Ken Amman was making repro's. I'm using a set and they're nice. 810-621-3665
Ken had no brackets left when I talked with him at Central Regional. They would no longer be available from him or the new owner.
Check the following sources:
Bobs Auto Glass sells a visor which has brackets which "may work" for the Hudson application?
http://bobsclassicautoglass.com/visors.html0 -
I Have Apair Of Out Side Brackets But I Do Not Have The Center One Let Me Know If This Helps
Hudsonly
Paul0 -
The center one is easy, we can make that. Let me know if you need help.0
classictint wrote:Wondering if anyone might have an extra set of brackets for my Stepdown Visor... tried all the Hudson sources on my side and have had no luck... any leads would be appreciated..
Thanks in advance
Lance
http://stores.ebay.com/Loupeestuff-Classic-Car-Parts_W0QQcolZ4QQdirZQ2d1QQfsubZQ2d33QQftidZ2QQtZkm
Check with this Ebayer she deals with some neat stuff including visor parts etc. Also have seen Hudson rear window blinds. Good luck, Ron0 -
If anyone has a set they could loan me because i found someone who said they could make a set for me if they had a set to use as a template.. name your conditions for a deposit.
Lance classictint1@msn.com0 -
classictint wrote:
Lance, I will help defray the cost of your making brackets if you make a second set for me. I have a visor, but no brackets. Though I am months away from needing them I would like to have a set in hand. Let me know how I can help with deposit or in fabrication or just in handing over cash for a set you make up from the originals. Thanks. Geoff.If anyone has a set they could loan me because i found someone who said they could make a set for me if they had a set to use as a template.. name your conditions for a deposit.
... make extras and sell them at the National next year?0 -
Geoff,
I was going to have at least 10-20 sets made depending on the cost... im surprised more repops werent produced... these brackets are more scarce then i thought.
Thanks
Lance0
- 114 Hudson 1916 - 1929
