52-54 spicer rear backlash help
Hi Guys
One thing I never had to do before was shim up a spicer rear-end to proper specs of .003-.006 clearence's. Any suggestions as to were to obtain shims and if I should attemp to started pressing bearings. Or should I take this to a rear-end shop to safely pull those bearings. Just a shot in the dark if anyone has done this before.
Thanks Russ
Thanks Russ
Russ these guys have the shims and here is a help guide. I pulled and replaced my bearing in my shop.
http://www.differentials.com/install.html0 -
russmaas wrote:
You need a special housing spreader for when you get it all set up you must spread the house 0.021 thousand of an inch to add a 0.010 shim on the left side to preload the carrier bearings. Those 2 holes you see it the housing is where the spreader fits. Any other way you will have trouble later on. Walt.Hi Guys
Thanks Russ0 -
walt's garage-53 wrote:You need a special housing spreader for when you get it all set up you must spread the house 0.021 thousand of an inch to add a 0.010 shim on the left side to preload the carrier bearings. Those 2 holes you see it the housing is where the spreader fits. Any other way you will have trouble later on. Walt.
This is exactly the procedure to follow. Dana axle housing has to be spread to be set-up correctly.0 -
Were would you obtain a spreader as seen in the manual?0
russmaas wrote:Were would you obtain a spreader as seen in the manual?
Google Search for ..Dana Axle housing spreader... produces a number of providers:
http://completeoffroad.com/i-122838-housing-spreader-dana-30-thru-dana-80-yt-s01.html
http://www.thepartsbin.com/cartools/speciality_tools-differential_housing_spreader__lpr_otc_col__model_7071_rpr_-d.html
Quite a spread in the costs too....
Article on Dana rears showing the use of the spreader and the pinion dial gauge.
http://medusa.ih8mud.com/cruiser/D60HD/D60.html0
- 114 Hudson 1916 - 1929
