Took a break, now I am ready
Hudsonrules
:)Last week I was really fed up, removing the clutch from my '37 Terraplane and some minor issues with my '49. I took some good advice from this forum and stayed away from my Hudsons for several days and cleared up my mind. Put a rebuilt generator in my '49 and it went well, tinkered with the Terraplane and realize that I will have to move the engine foreward to remove the clutch. There is not enough room to pull the transmission back and out due to the overdrive transmission. So now I have a clear head and am more relaxed to finish the task. I had to realize that thses cars are not daily drivers and I have time to do it right. Thanks for all the input when I was down in the dumps. Have a great day, Arnie
In regards to pulling the engine + overdrive trans. on the '37, I'll just tell you that it can be done by one man, using a hoist with casters. Of course, you will have to remove the radiator but then, so long as the hoist can roll smoothly on a concrete floor, you should be able to pull and replace it without any assistance. I once did it on a dirt floor by rigging up a "railroad" of planks on which to roll the hoist. It's a lot easier to work on the clutch, transmission and engine anyway, when they're not in the car!0
Arnie, I got into the same mindset with my 29 DB pickup. Recently I got back to it. Tonight I checked spark and have it to all four plugs so I think I have a fuel feed problem. So now it's on to the carb. I'm not real familiar with updraft carbs but as long as there is vacuum it should be pulling gas. I might have a plugged jet. I guess my next project is pulling the carb and looking inside it. On another side though I put a battery cable on the Hash from my Dodge Dually, big cable means more cranking speed. Who would a thunk it huh? I don't know how much faster it's turning over but the difference is noticable. I guess the old cable was for 12 volt but smaller guage, the big cable must have much less resistence.
Harry0 -
Hi Harry, Sounds like you have some irons in the fire. If my memory serves me right, 6volt systems require either one or two gauge cable. I have used a smaller gauge for a 12 volt as a ground and had poor results. Now I double check the connections and use the heavier cables. Lights are brighter and it starts easier. Have fun with your '29. I do not remember seeing any early Dodge pickups other than in a picture. The weather is beginging to change so it is time to get the toy's ready for the next several months. Have a good day. Arnie0
Arnie
Glad to hear the good folks on the forum "talked you down"
It's hard to walk away when you all you want to do is make forward progress - but sometimes it's mandatory~!
I don't know how many times I've fought and fought [insert any part, procedure here] - to walk away and come back later and have it slip right in
Take your time - and be safe!
Arnie, that is one of my many faults, I try to do too many things at once. The 29 is testing me right now. The engine really drags when trying to start. I think I need to tear it down and rebuild it, I'm just not sure if I can get all the parts for an 80 year old plymouth engine.
Harry0 -
:)Hi Harry, Regarding your '29 project, You may have to do a little research but a company called "EGGE' specialized in vintage car and truck mechanical parts, I am sure they can assist you in needed engine parts. I am pretty sure they are still around even though I have not seen any of their ads latley. I only get to one or two swap meets a year now, but I used to see them quite often at major meets. Good luck. Arnie0
Hudsonrules wrote::)Hi Harry, Regarding your '29 project, You may have to do a little research but a company called "EGGE' specialized in vintage car and truck mechanical parts, I am sure they can assist you in needed engine parts. I am pretty sure they are still around even though I have not seen any of their ads latley. I only get to one or two swap meets a year now, but I used to see them quite often at major meets. Good luck. Arnie
Here's the link
http://www.egge.com/0
- 114 Hudson 1916 - 1929
