Minimum Head Thickness for 262?
I measure valve lift then mill the head to that depth. More Compression gives more HP. Measure to the shallowest depth of combustion chamber though or you will need to use shorter reach S/Plugs. Best Co. Permbond Gasket from Randy Maas or Dale Cooper is the best available today...0
- 114 Hudson 1916 - 1929
