bellcrank
duncan wrote:Is there a differance between a bellcrank from a single 2 bbl and a twinH .
duncan
yes and different standard and hydramatic0 -
Yes there is. There is a difference in a 3 speed twin H and a Hydro twin H. There are also different bellcranks for twin H Wasp, and standard Wasp as well as the standard bellcrank without twin H. There are a few others also.0
Our 54 Hornet Hollywood had a single 2 bbl carb and hydra trans now i changed it to twin H But when i hooked everything up it was backwards
If i cut off the tab that the rod with the tierod ends are on and welded it directly across from present position would that work. thanks duncan0 -
Duncan I had the same problem and ended up welding another lever to the twin h set up further to the front of the engine as you can see in the attached pictures. ( I hope ) . The lever I used has extra holes and I finally used the 2nd one from the left.0
Dang it where are the pics?0
We'll try again0
*&$%^#$%*&^%$0
My pictures are way to large, thats why they won't post. Anyways Duncan I used the setup from the donor car which was a 53 superwasp to my 54 wasp. It had the linkage going to the lower bellcrank just forward of the starter. I had a rod going up from there to the throttle linkage. What I did was use all of that and then weld a lever on to the twin h set up for the vertical rod to connect to. As your foot pushes the gas pedal down the linkage draws back and pulls the twin h lever down towards the oilpan. I hope that makes sense. If I could I would post the pictures they would show it quite well.0
- 114 Hudson 1916 - 1929
