Need help on overdrive.
Huddy42
Huddy42 Senior Contributor
Can anyone tell me the difference between an R9B overdrive and an R10B overdrive. Is there any difference internally between the two.
What I can gather the R9B suits 1946-7 Hudson and the R10B suits1947-1949 Nash.
This number is stamped on the side of the O/D Unit.
Any help would be appreciated.
Les.P.
  • Clutchguy
    Clutchguy Senior Contributor
    Les,if the rear trans case[Overdrive part] is bolted on with 5 bolts that go thru to the main case, like the 41-47 Hudson,it will have the same insides. If it is bolted on with only 4 bolts, the parts inside are mostly all different. I forget where I saw a chart of all the different B/W overdrive units??. I hope this helps.
    Les.P.
    You will find a wealth of information at this site:
    http://www.amccf.com/tech/amc_manual_trannies.html
    Good Luck :)
  • Huddy42
    Thanks for the input guys, the more info I get the better it is.We are never to old to learn, especially about Hudsons.
    Les.P.
