Part number for Jet points
Barry, The OEM AutoLite number for Jet points was IGW 3028BS. Try NAPA part # CS 720A. I believe that will work.0
Thanks Hudzilla!
Barry0 -
Oh, I forgot about the condenser. The OEM AutoLite part number was IAT 2015R. As far as I know the current number for NAPA is now AL 869. I believe the current number for Standard is AL 111. Good luck Barry.0
The correct tune-up parts for a Jet with the Autolite IAT-4202 distributor are as follows.
Points: NAPA CS719A Standard AL-4652XP
Condenser: NAPA AL868 Standard AL-118X
Rotor: NAPA AL112 Standard AL-152
Cap: NAPA AL112 Standard AL-138
Coil: NAPA IC7 Standard UC-14X
The CS720A points are for a '55 Hudson with the Packard V8. The AL869 condenser is for the '51 - '56 Big Sixes, but would most likely work on the Jets.0
- 115 Hudson 1916 - 1929
