Need:Timing cover crank seal.
jjbubaboy
jjbubaboy Senior Contributor
Hey all,
Wondering if anyone knows if the crank seal is available as a NAPA item for the timing cover on a 36T 212? Or even available at a 'todays' auto parts?
Thanks,
T Jeff
  • Geoff
    Geoff Senior Contributor
    The only number I have is from a pretty old book of intergange parts put ourt by the late Lou Bacchus. 1934-'56 all used the same front timing cover seal, and the numbers I have are Chic/Raw 13823, or 18810, or National 50084. It's a pretty standard type of seal, and should be easily available.
  • mars55
    mars55 Senior Contributor
    Lou Bacchus's Swaps Manual also said that that is the same as a 50's Chrysler six in that case it's a National 6636S, NAPA/CR 21814 with a width of 0.687 inches or a National 6186, NAPA/CR 21820 with a width of 0.469 inches. The other dimensions are ID 2.1880" OD 3.194". The Swaps Manual also gives a Victor 49099 or a Fel Pro 2539 as a replacement. These seals and the C/R 18810 and the National 50084 (now called a 450084) cross to a NAPA 18785 with dimensions of ID 1.8750", OD 3.0010" and width 0.3130". You are going to have to measure your seal to see which one of these seals is right.
  • jjbubaboy
    As always,Thank you!
    I am sure one of these will do the trick.
    T Jeff
  • Park_W
    Park_W Senior Contributor
    NAPA 49099 is a good current number, I think.
  • mars55
    Indeed 49099 is good number. It cross to NAPA 18785 and to National 450084.
  • jjbubaboy
    Yes team you are winners!!
    Indeed the 18785 (National 450084) was the correct item.
    Fits like a glove and at only $11.99 it was the perfect ticket!
    THANKS as always,
    T Jeff
