Fog Lamps
I picked up a pair last week from local NAPA. I gave them bulb numbers and they had them next day.0
couldn't find a number for the sealed beam unit on it. Will the number on the plate on the housing do?0
GE 4415A is the number you need.
Dave W. Fl0 -
Thanks SuperDave. These are weird sealed beams no plugin connector but what looks like the end of a flashlite bulb then the socket in the housing snaps over this.0
Dunno about that? I assumed you had the Hudson Unity fog lamps. They have two screw terminals on each one.
Dave W.0 -
Nah, I have the Guide 2025A Fog Lamps. Its a sealed beam fog lamp but it has a button type connector on it. The end of the sealed beam looks like the end of a bulb the round connector snaps on to that. I will take the old lamp down to NAPA and see if they can match it. If not I can always get them from Kanter.0
