Front wheel cylinders
Richie
Richie Senior Contributor
I called a local parts store with wheel cylinder part numbers that I took from researching several forum members web pages and came up with WC9090 and WC9091 for stepdowns 48 to 54 not including the Jet. The parts store said those numbers will fit 53 and 54 but not a 51 Pacemaker. What would be the difference? Any help is appreciated. Thanks, Richie.
  • 53jetman
    53jetman Senior Contributor
    Riche - Those are the correct part numbers for all Pacemakers thru to the 1954 Wasp.
    Jerry
    53jetman
  • drdoug
    drdoug Senior Contributor
    Richie,as Jerry said,they will work the same. The difference in Pacemaker,Wasp the cylinder bores were 1-1/16th. VS. 1-1/8th, but exactly the same as exterior and bolt pattern. Why they did this-who knows??.
  • Richie
    Jerry
    53jetman
    Thank you Jerry. Richie.
  • Richie
    Thank you Doug, that explains it. Richie.
  • Richie
    Ken U-Tx wrote:
    Most likely it was done because the SWB cars weighed @10% less and the weight distribution shifted slightly in favor of the rear axle. Putting the 1-1/8" cylinders on a Wasp would decrease the pedal effort some, with a slight increase in pedal travel. Putting the 1- 1/16" cylinders on a LWB is less desireable, higher pedal effort, and possible the rear brakes might lock before the fronts in very hard braking.
    Thank you Ken, I have made notes. Richie.
  • super651
    super651 Senior Contributor
    Richie, A local Hudson owner has the 11 inch Hornet brakes on the front of his 47-8 cyl Hudson. And to help in Stopping a bit better he installed the wheel cylinders that fit the 1966 Ambassador with V-8 engine. They are 1 3/16 while the Hornet is 1 1/8 and they line up with the brake bands. I test drove it last weekend and it Stops much better than my 46 with Hornet brakes up front.
    Checker # Raybestos--WC37125 and WC37126 ( heavyduty for the AMC)
    Hope this helps. Rudy
  • Richie
    Rudy, thanks for that info. Nice to know there are more options out there. Richie.
  • mars55
    mars55 Senior Contributor
    For those who want the 1 1/16 wheel cylinders, here are some part numbers.
    Left - Raybestos WC37083 or WC9090, Bendix 33461
    Right - Raybestos WC37084 or WC9091, Bendix 33462
  • Richie
    Thanks mars55, I'll just keep adding to my notes for future reference. Richie.
