Question on 'proper' brake maintenance.
jjbubaboy
jjbubaboy Senior Contributor
Hey all,
I was reading some old posts regarding brake drum turning and proper fitting of new shoes to the drums.
Since I dont know if my 36 T has ever had this done and the shoes look pretty thin is this something I should do? Although the drums dont seem scored they do seem a little glazed.
Any fellow Washington state members had this done? If so where??
Thanks!
T Jeff
  • Jeff, don't wait until the shoes start to score the drums, if they are getting thin you should probably think about doing a brake job. The drums may not need turning unless they have been wearing hard. Most of the time a deglazing will work wonders unless the rim has a lip from wear. I would get the new shoes arced to the wheels though, that helps them seat properly so you have solid contact across the complete shoe.
    Harry
  • drdoug
    drdoug Senior Contributor
    Did you ever share what resolved the cooling issue with your T-Plane?:rolleyes:
  • jjbubaboy
    Hey Clutch guy,
    I think so...Since the fall/winter here in Washington is so wet and chilly I havent actually gone out for a drive. Mostly due to just working on all the stuff I want to get done for next year. But I changed to the bypass pump and outlet and added a t-stat and that seemed to work great, at least for the time I was running her. Then developed some carb leakage and running issues so shut her down pulled the carb and sent it out for a complete overhaul.
    T Jeff
  • hudsonguy
    hudsonguy Senior Contributor
    Harry
    Just curious where one get's shoes 'arced' these days. Everyone I talk to said that OSHA did away with that entire service around here (Wisconsin) back in the 70's or 80's.
  • My local parts store here is Socal does it. Osha probably stopped it when asbestos was in brake shoes. I don't think that should be an issue anymorre. I've been told it doesn't matter anymore but I still believe the better the shoes fit the better the stoppinig power. I know the chain stores sell the shoes without arcing them and there doesn't seem to be a problem so it is most likely my old school ways that keep me having them done.
    Harry
