37 Terraplane PU ribbed bed bottom
Kdancy
Does anyone know of a source where the ribbed material for pu bed bottom can be purchased ?
Thanks!
Thanks!
Do you have specs? Material thickness, the rib size, spacing, etc. Also, how are the outside edges attached?0
I have a copy of the bed blueprints but they are at the sheet metal shop right now. I will post the answers when I pick the sheets back up.0
Kdancy-
I don't know of or have never seen a source, but bentmetal here in this thread can manufacture a bed floor for you. The other option is if you're customizing, then chrom strips and wood in between is always a nice touch.0 -
This website makes ribbed Pickup beds for Studebakers, but if the measurements work, they may work on your project.
http://www.classicent.com/studebaker.php0 -
http://s294.photobucket.com/albums/mm97/studebaker2/37%20Hudson%20Terraplane%20PU/
This is the album link on photobucket. I have the prints in there. I also sent a copy to classic to see if they can build the ribbed floor.0
- 97 Essex Super 6
