Where do these go
Unknown
These rubber seals came with my Car and I am not sure where they go. I think I have figured out were the pair goes but I do not have a clue where the bottom one goes.
  • Looks like a bikini from 100,000 BC...
  • drdoug
    drdoug Senior Contributor
    SR ,the other rubber parts are for the core support. They go on either side,at the top. There is also supposed to be a flat piece of metal that goes over to retain them. The purpose is to direct more air thru the radiator. The rubber flap will go against the front cross valance. 2 bolts hold them on either side. Some of these have a hole in them to allow the headlight wiring to go thru also. The rubber flap for the M/C has a metal bar that bolts to the frame with 2 coarse body bolts. It is designed to protect the M/C from rocks-etc.,but if not installed correct,deems useless. When installed correctly,the flap is about 45deg.or more and creates kind of a cup protecting the linkage. Hope this helps.
    Thanks Guys.
    I thought the two went at the core support because of the hole location. I did not know about the metal piece, it looked like something was missing.
    Thanks again.
