Back to the Vac
[Deleted User]
Vacuum tank that is. The fuel feed on the top of the vacuum tank is half in something. It doesn't appear to be tapered like pipe threads. A half inch brass fitting goes in but it doesn't sea as the bottom looks like a flared fitting goes in so maybe that is what I'm missing. Does anyone know what the fitting is? Also, does anyone have a NAPA number for the cork gasket to the top, eight screws hold it down.
Harry
  • Have to make your own gaskets from rubberized cork (easy to make). The top is the part you have to be carefull with. It breakes very easy (pot metal).
  • Ron, I can make the gasket, what do you know about the fuel inlet fitting?
    Harry
  • Oh Oh, I was looking at the repair manual you sent me a while back and it shows a strainer screen on an elbow, that must have a gasket that it tightens down on. I wonder it anyone has those strainers to sell? I'll have to go back through the earlier threads and see who is doing repairs, they may have the strainers.
    Harry
  • Spencer Yarrow
    Spencer Yarrow Expert Adviser
    if you break the pot metal top check the thread on hudson & essex reproduction parts. They make new ones.
  • Thank you Spencer, I wonder if they also have the strainers? What is the link to the reproduction site?
    Harry
  • Spencer, did a search and found the site, they don't show the strainer but I will write them and see if they have it.
    Harry
  • Okay, it looks like the fuel inlet is a banjo type fitting with a half inch threaded plug with a strainer on the bottom. I looked in my junk drawer and I don't have one. I think this may be tough piece to find.
    Harry
  • http://www.myersearlydodge.com/index.php
    Has Vacuum tank parts.
    This is the top you should have.
  • Yep, that's it. I need the part that says from the tank.
    Harry
  • mars55
    mars55 Senior Contributor
    Checkout Myers Early Dodge web site given by Ron P. Their catalog lists the strainer screen and gasket you need under the Fuel section.
  • Mars55, thanks, the note to Myers Early Dodge is in cyberspace as we talk. I didn't see the fitting in their online catalog but they will probably know who has the parts.
    Harry
  • ESSX28-1
    ESSX28-1 Senior Contributor
    Harry,
    If you can't find the part in the US let me know. I've probably got one one in my spares (here in NZ!!)
  • Thank You Dave, I will do what I can on this side of the pond but it is good to know where I can find one if I need to.
    Harry
