Hudson Transmission Cluster Gear
Want to buy, NEW or NOS Hudson 3 speed Cluster Gear. Hudson part number is: 306824, Borg Warner number T86E-8A. Tooth count big to small: 32-24-19-14.
Email with your cost with shipping - KENSanjuana@aol.com delete KEN when using email address.
Note: Al S in AZ is not a source, we have talked already.
Thanks
Thanks
Thanks for the lead.... One last BUMP.... trans is headed to AZ in two weeks with or without a new Cluster gear.0
Here is something you might consider. A CJ Jeep with a V6 used a T 86 transmission with a cluster gear of 33-25-19-14. If I did my math correctly, using the Hudson gears with the CJ Jeep cluster gear will give you a correct second gear ratio, but first and reverse will be lower.
See this website.
http://www.4wheelparts.com/prodDetail.aspx?partNo=CRO944769&jeep-parts=true0 -
Speaking of tranny's has anyone tried a T-5 vs an overdrive ? I realise the shifter would have to go in the floor but an OD is a pain to get to work ?
PS: always remember drive into driven for the ratio0
- 115 Hudson 1916 - 1929
