Heater hoses
Does the heater hose that comes out of the water pump on my Jet got to the top heater core inlet or the bottom?? My heater is blowing out pee warm air. I want to make sure that is correct before I pull out the thermo, It might be the problem, it is only a 150 degree.:rolleyes:
Thanks, Barry Smedley
53 Super Jet
and a bunch of crosley's:D
53 Super Jet
Barry, Your hose from the pump goes into the upper copper stub on the heater box.The bottom one goes to the straight pipe on the Ranco valve and the other curved copper tube on the Ranco valve connects to the block head.0
You are right! They are backards!
Thanks, barry0
- 994 Street Rods
- 174 The Flathead Forum
- 602 Vehicles
