308 Head Gasket?
just spray the gasket with alum. paint0
GMPHH wrote:
Get a can of engine enamel silver, hang the gasket by 2 wires, then spray a thin coat on both sides but do not let it run. Let dry for 12 hours, then install. It must then be torqued in steps the correct way. 7/16 studs or bolts are 65 ft lbs, 1/2 inch studs or bolts are 90 ft lbs. This is included in Walt's tech tip books.I am changing the head gasket on a 308, six.
The book says to use a non-harding sealer. I have always used motor oil but this is my first flathead.
What do you folks recommend?
If you are using a modern gasket my understanding is you don't use anything on it, it will seal very well.0
Jimalberta wrote:
Check Hudson engines on the left side, Driver, and if you see oil marks from #3 and 4 cylinders, that gasket is not sealed or torque correctly. I paint all my gaskets to be on the safe side. Walt.If you are using a modern gasket my understanding is you don't use anything on it, it will seal very well.0 -
I have tried a lot of sealing methods and they all worked well. However these days I suggest buying a 'Permabond Gasket' available from Randy Maas or Dale Cooper.
All other Head gaskets I would spray Permatex copper High Tack on both sides then let it 'set up' a couple hours before installing.
Always Re-torque Aluminum Cold and Cast Iron Hot a couple times before heavy use...0
- 115 Hudson 1916 - 1929
