1936 Head Light Lense
Browniepetersen
My Hudson was converted to seal beams. I am doing a restoration and need to find head light lenses, reflectors and the mechanics that screw into the buckets that have the attach or tightening screw that sticks out the bottom of the buckets. I also need to know if all 36 lenses are the same (there is a single lense on eBay for $45. Is that a good or bad deal?) or are the buckets on the eight's larger and take a different lense?
Also, I need a nice set of fog lamps or driving lights to attach below the headlights. I think Lucas style are aftermarket, but what is the right lights?
Brownie,
'36 light buckets do show up at Nationals and Regional swap meets. I have found a couple over the years. Check the parts book, I am pretty sure that both Hudson & Terraplane, all models in 1936 use the same headlamp lenses, reflectors and springs and such. You might call Carl Webber in MA, he has lots of pre-war parts and may be able to help you out.0 -
Might Have Lenses, Let Me Know If Need And I Will Research, Bill A.0
- 115 Hudson 1916 - 1929
