Expansion Plugs 35 Terraplane 6
35 Terraplane
I see a set of expansion plugs on Ebay, Dorman #E16 listed as fitting 36-39 Terraplane 6. Does anyone know if these will fit a 1935 Terraplane 6? I have a leaker in the head that needs replacement.
tjfxmk wrote:
If one is leaking then the head will have to come off so as to change them all. Can't get to the ones on the exhaust manifold side. Once off, you can measure the hole, go to napa and pick up a set. Walt.I see a set of expansion plugs on Ebay, Dorman #E16 listed as fitting 36-39 Terraplane 6. Does anyone know if these will fit a 1935 Terraplane 6? I have a leaker in the head that needs replacement.0
- 115 Hudson 1916 - 1929
