'49 Hudson charging system woes
Hudsonrules
Have you check all related wiring and fan belt tension?0
Sounds Like Ground Strap To Motor Doesn't Have Good Connection.0
Ken U-Tx wrote:Make sure your ARM & FIELD wires are not grounding out anywhere. If they are, the dash light will stay on when engine is running and generator will not charge since the field windings will not be energized with either wire grounded out.
I hate to contradict my good friend Ken, but if the Field wire is grounded on these Auto-Lite systems, it bypasses the voltage regulator's "regulating section." Unregulated, the generator will produce excessive voltage (and thus current) if the engine speed is much above idle. That would make the GEN light go out, but then would start blowing bulbs and/or overheating wires. If the ARM wire were grounded and everything else were OK, that ARM wire would get mighty hot in a hurry. You'd see it smoking or smell it.
Was the generator or its mounting bracket freshly painted? If so, maybe the generator's not grounded to the engine.0 -
Does the lite go out when you rev up the motor?0
Good question, Russ ... let's not overlook the basics!0
switched to single wire 12 V alternator, easy to do and far less trouble.0
I have one of each, Jim, and enjoy the benefits of 12v on the air-conditioned Hornet. But let's not discourage the folks who'd like to keep it original, for whatever reason.0
:)Thanks for all the advice and idea's on this problem. I am sure that there is a grounding issue somewhere. But to be safe, going to rewire the gen to regulator and the amp light. I should have gone the one wire alternator and switched to 12volt, it would have been easier and less costly. Live and learn. Is it possible that a bad ignition switch could be the problem? Just an idea. Thanks,, Arnie in Nevada0
Arnie, rewiring or at least checking the wire to the "T" terminal on the VR is a good idea, since, if that wire is frayed and touching ground anywhere, the GEN light's going to stay on when the ignition's on, whether the generator's charging or not.0
If you should give up on the original system and opt for a 12 volt system(which I recommend you keep original if you can), Don't use a one wire alternator. Use the standard three wire GM alternator so you can use the "gen" light. Otherwise, you will have to install a voltmeter or ammeter to monitor it. I think park has posted the wiring for the setup. Perhaps on Dave Sollon's site. It's easy and the altenator is cheaper and available at all auto parts stores. Sometimes the alternator will have a wireing diagram enclosed to aid in troubleshooting.0
Good point SuperDave, now that you mention it that is what I did and the gen light works as it should..0
- 115 Hudson 1916 - 1929
