Hydromatic Differences Jet vs. Stepdown
hudsonguy wrote:Is the Jet Hydromatic transmission different from the Hydromatic that was installed in the stepdowns? I assume it is, but thought I'd ask someone who knows for sure. Thanks for the help. Doug
I'm sure it is different. Model # used on the Jet was J-52, and the models used on the bigger Hudson engines were designated H-50, H-51, H-52, etc. The Jet 202 engine was a bit short on the torque of the larger Hudson engines, and probably would not have performed properly with the same Hydro unit. It did, however, perform very well with the J-52 Hydro. The 202 engine handled the Hydro much better than the '55 Rambler engine did.
Jerry
53jetman0 -
Jerry,
I kind of figured as much.
Thanks,
Doug0 -
haven't looked into it,but generally,smaller cars with less torque would have fewer clutch plates inside,also the torus coupling would be smaller diameter,and the valve body would probably shift at a different rate.
I know this is how they were built for Rambler,Nash etc. so I assume the same for Jet.
I can check part numbers if needed.0 -
yorgatron wrote:haven't looked into it,but generally,smaller cars with less torque would have fewer clutch plates inside,also the torus coupling would be smaller diameter,and the valve body would probably shift at a different rate.
Although I've never had one apart, I've heard this to be correct.0 -
It has one less clutch in both the front and rear drum. I believe that the difference was in the thickness of the clutch piston. Torus coupling is smaller, some used a large O- ring instead of a gasket. Lou Cote0
- 115 Hudson 1916 - 1929
