Terraplane Trans: Part Two
Hudsonrules
Arnie, I'm not sure precisely which transmission you have in the car, currently. If it's the original '37 tranny it won't be an overdrive. If it's a 1940 overdrive with the 1937 gearshift lever bolted on, you need only remove the four bolts and lift, as I recall. Neutral is probably a good idea, if you can shift it there. If it is any other overdrive transmission I have no idea how the shift lever is connected!0
