Question on pulling engine/trans
I need to pull the engine and transmission from my 54 Special. The front end is completely off the car; fenders, hood, radiator, etc. Is it easier/okay to remove the engine and transmission as a unit or should they pulled one at a time? Does the same apply for reinstalling?
I have pulled an engine by itself once before so am not a complete novice.
Thanks for your feedback,
Doug
Doug
Doug, I have found it much easier to pull them as a unit. Also since the front end is off it is easier to replace as a unit..If not OK I guess I am in trouble. The only way it could be easier, at least in My opinion, is to have someone else do it!
Bob0 -
Yep, just buy or rent a "cherry picker" & pull the whole unit + same when re-installing - "piece of cake", LOL.0
Doug, BJ is right -do it as a unit. Save yourself the hassle of tying them together after the fact. If you have the whole front clip removed,this is a no brainer. In 10 minutes its over and done.0
Bj, Old Hudsons and Hudzilla, thanks for your helpful responses. That looked like the way to go but things are not always as they appear.
Doug0
