Speedometer Gears Info Needed
Has anyone ever tried putting in different DRIVE AND DRIVEN gears to correct a speedometer when putting a late model rear end in a 30's car ? Putting a 3:07 in my 37 Terraplane. Drive and driven gears are such that a given drive gear will operate several driven gears. The 37 DRIVE gear is .985 I.D. X 1.940 O.D. X .750 wide , no inner splines and held secure by just the tension against it. If anyone has a DRIVE gear and or driven gear they would part with from a car that had a 3:07 rear or close to it I'd like to give it a try. I think the O.D. would be the only critical factor, width and I.D. could be built up/machined down to size. Thanks, BUD
Since 3.07 was not a factory option in '37, there might not BE any gears available for that praticular transmission. This wouldn't preclude you from making them (with a the help of a good machinist), I'd think. I've also heard of universal gear reductions that can be attached to the transmission and adjusted to fit the ratio, but have never checked them out.0
Jon B wrote:
---- HI JON, I've used the adapter gidgys, they work fine and have a whole mess of little gears in them that are arranged/re-arranged to correct a reading. Am wanting to try something likely not done before, might get lucky and later gears can be made to work .Since 3.07 was not a factory option in '37, there might not BE any gears available for that praticular transmission. This wouldn't preclude you from making them (with a the help of a good machinist), I'd think. I've also heard of universal gear reductions that can be attached to the transmission and adjusted to fit the ratio, but have never checked them out.0 -
37 Terraplane#2 wrote:
Take your car to a speedometer repair shop that has a dyno and they will adapt a little transmission to your transmission and hook up your speed cable to it and you are all set. When I installed my 2:73 gear ratio in my 53 Hornet, this I did and no problems. They will issue you a slip showing before and after speeds. Cost me $90.00. Walt.Has anyone ever tried putting in different DRIVE AND DRIVEN gears to correct a speedometer when putting a late model rear end in a 30's car ? Putting a 3:07 in my 37 Terraplane. Drive and driven gears are such that a given drive gear will operate several driven gears. The 37 DRIVE gear is .985 I.D. X 1.940 O.D. X .750 wide , no inner splines and held secure by just the tension against it. If anyone has a DRIVE gear and or driven gear they would part with from a car that had a 3:07 rear or close to it I'd like to give it a try. I think the O.D. would be the only critical factor, width and I.D. could be built up/machined down to size. Thanks, BUD0
