Engine Temp Sender
RG53Hornet
Anybody used a modern replacement temp sender that will work with the stock gauge? I want to hook it up to my Chevy small block, will be 12-volt negative ground. I checked Ken Cates page and searched the archives, but found nothing.
Thanks!
Thanks!
Original sending unit will work fine. I have used same one on our 51 for over 15 years with negative ground 12 volts.0
Well...I also do not have the original. Is it still available someplace?0
sorry, I didn't notice you wanted one to fit small block chevy. I'm not sure of thread, but if it is 1/4" pipe thread, you can try Echlin TS-6464 or TS6164 or Wells TU-1 for all AMC 6 1956/57, all chrysler 8 56/56 and all Hornet V8 1956/570
Thanks! I'll bounce those numbers off some parts counter guys and seee if I can find one.0
