Hudson help.....
i have a straight six sitting in my garage that my dad got wayback when... tryin to clean the garage and dont want it.. i believe its a hudson or a hollywood motor. i have the motor trans both manifolds, flywheel pressure play clutch. motor is fully assembled with generator on it. the only thing is i dont know what i have. the casting numbers on the head are
301766 with a date of 2/5/48
and on the block its got
300001
cwc
1
that is how it is on the block. i have pics tures i have pics just dont know how to attach them.
thank you
nick
300001
cwc
1
thank you
nick
Suicide_36 wrote:i have a straight six sitting in my garage that my dad got wayback when... tryin to clean the garage and dont want it.. i believe its a hudson or a hollywood motor. i have the motor trans both manifolds, flywheel pressure play clutch. motor is fully assembled with generator on it. the only thing is i dont know what i have. the casting numbers on the head are
300001
cwc
1
thank you
nick
E-mail me the pictures and I will post them for you:
My51Hudson@yahoo.com0 -
Hudson308 wrote:. That serial number is as good as a picture. If indeed the engine was made in 1948, it's a 262 cubic inch 6, and it will have a serial number starting with 481 or 482. There is also a date code cast immediately below the distributor boss in tiny characters. Those characters are a bit less reliable, but will end with a 7 or an 8 on a '48 262.
I thought the engine numbers DIDN'T have the model number stamped with it.
Alex Burr
Memphis, TN0
