Interior sunvisor installations
Experiencing difficulties with upholester who aleady installed headliner, but dome, courtesy lights L/R visors and center radio antenna weren't completed. As we want to be real careful poking around to find proper installation, does any member have recommendations and or instructions.
Ray
Ray
I ended up (1952 Hornet) pulling the trim and pulling down the headliner so that I could locate the bolt holes, check bolt size and the angle that the bolts needed to be positioned to go in. It was not as tough as it seems and it was well worth the time spent...0
Browniepetersen wrote:I ended up (1952 Hornet) pulling the trim and pulling down the headliner so that I could locate the bolt holes, check bolt size and the angle that the bolts needed to be positioned to go in. It was not as tough as it seems and it was well worth the time spent...
Thanks Brownie,
I did find some before and after pictures of my 1953 Hornet purchased from Rudy Bennett / Black Beauty and have a better idea of placements.
Maybe some member can help with information / supplier of stainless steel narrow piece that is inserted between permanent nad removed dash board, see picture.
Thanks again,
Ray0 -
Be sure to take into consideration the angle of the bolt as it goes in. I thought it to be a bit difficult...0
