Steering Column Sleeve Bearing
ski4life65
I need to get my steering column sleeve re-chromed, and cant get the inside bearing removed. Are there any tips or procedures that will help, or is this not removable?
thanks
Don
thanks
Don
ski4life65 wrote:
It's easy. Just turn it upside down. get a broom, cut the end off, put it inside from the bottom and tap away. It will only come through the top. When it goes back in it has to sit on the 2 little bumps inside. Very easy job. Pack the bearing with wheel bearing grease when you reinstall. Walt.I need to get my steering column sleeve re-chromed, and cant get the inside bearing removed. Are there any tips or procedures that will help, or is this not removable?
thanks
Don0 -
thanks Walt0
